International 540 Plow
Joe
02-13-2003 05:26:32
Have a chance to buy an International 540 plow fairly cheap. Some of my neighbors use International 510's and really like them. I know the 540 is older, but what differences are there in them and how will it compare in performance? Thanks.
TP from Central PA
02-14-2003 04:46:11
 Re: International 540 Plow in reply to Joe, 02-13-2003 05:26:32
We bought one to replace the Case 4-14 semi mtd. plow we had. Works light years better than those Case's and it seems stronger. I would buy another.
Hugh MacKay
02-13-2003 09:53:24
Joe: The 510 is newer yes, but it is also heavier built plow, and more clearence. Most of that added weight and strength is in the main frame leading to the hitch. Look that 540 over quite well. I have seen a few of them with main frame a bit out of shape. I guess we know the reason for heavier frame on the 510. I also don't believe there was any need of twisting or bending the 540 other than rough use.
Tim(nj)
02-13-2003 08:40:04
I have a 540. It has less trash clearance than a 510. Otherwise a good plow.
