J.D. #44 Lube Question
Mike
02-10-2003 17:57:38
On the trip side of the plows there is a valve that comes out of the hub ( looks like a tire valve but bigger). Is that the place to get the gear lube in? If so what tool is used to pump it in? I know the case needs lube but that is the only place I see to put it in. Thanks
ET
02-11-2003 06:41:37
 Re: J.D. #44 Lube Question in reply to Mike, 02-10-2003 17:57:38
That tube should have a grease fitting in it for multi purpose grease.
Mike
02-11-2003 09:44:05
 Re: Re: J.D. #44 Lube Question in reply to ET, 02-11-2003 06:41:37
The tube has threads on the outside, none inside. So does the housing for the trip mechanisim take gear oil or grease?
ET
02-11-2003 11:44:41
 Re: Re: Re: J.D. #44 Lube Question in reply to Mike, 02-11-2003 09:44:05
I think the lubricant in the lift housing should be a thin grease or thick oil depending on how you look at it. I use john deere corn head lub. The tube with threads on the outside is most likly a piece of 1/8" pipe someone screwed in there. The fitting I have put in is a couple inches long and 1/8" pipe thread. You might screw a coupler on the pipe thats there and put a fitting on that way.
