Magneto parts
Damon
02-10-2003 14:48:00
I have recently purchased a Massey Harris 701 baler. The baler is powered by the 85mm bore petrol Standard engine as found in the Ferguson TEA20 tractors. The main difference is however is that instead of the distributor a magneto is used so as to remove the need for battery and generator. According to a Gregory's repair and maintenance manual the magneto is model 4VRA V160.
I was wondering if parts for this magneto are still available, preferably in Australia but the existance overseas means that I could possibly find them here.
Thanks in advance,
Damon
Gary
02-10-2003 20:11:09
 Re: Magneto parts in reply to Damon , 02-10-2003 14:48:00
If you need to use thebaler right now and don't find what you need to repair your magneto, you can get by temporarily by converting your mag to a distributor. Disconnect the wire from your internal coil that is hooked up to your points and condenser. Run this wire to a coil and run a hot wire to the coil from the other end. Unless this TE-20 has been converted in some way, it is a positive (plus) ground, so your hot wire will got to the minus side of the coiland the plus side to the points and condenser. You will still be able to convert it back to magneto when the parts become available.
