Mixer pics for Bill-WV
Jim.UT
02-07-2003 15:32:36
third party image
This is the pto extension that bolts to the back of a Ford tractor. The inner splined sleeve on this was the old 1-1/8" size so I had to find a new 1-3/8" replacement. Found it at Hub City in SD.
third party image
third party image
A couple of shots of the extension assembly installed. My diff casing has a chipped off bolt hole at the bottom, so I didn't feel comfortable having this thing held on with just 3 bolts. To get around the problem I made a mounting flange out of 1/4" (I think) scrap steel. It is held in place by the pto shaft mounting bolts.
third party image
Here's the tire on the mixer drum being spun by the pto extension. I find that I get best mixing of cement at about 1000 engine rpm. I hope this helps.
