Errin...See the pic is from William Ransom from PA, so not sure who I am addressing. I'm an old PA boy from near Pittsburgh, but moved west in '64 and never even though of moving back. Unfortunately I don't have a digital camera yet, but will try to get some pics and scan them and post, or at worst, make a sketch, scan and post that. Your pic doesn't look a lot like what I have, but then, it doesn't show the gear box assembly very clearly. Looking down from the top would be easier to compare, but don't go to the trouble of doing another pic if you don't have one already. I'm at work, and can't bring up a good mental pic right now, so can't describe what I have, but will try. Will take a hard look this evening and reply then with at least a sketch. I can tell you this much...there is a sheet metal cover with a tab to grab to open it, over a recess that looks like a compartment to store spare blades, guards etc. on top, with NI raised letters on it. Kinda poor design since it isn't seqaled in any way and fills up with rainwater since it has no drain hole. There is a roughly circular part of the gear box assembly - maybe 8"-10" in diameter, with the top held on by maybe a half-dozen bolts around the edge. It seems to be a mechanism to raise the bar sssembly - or at least provide an assist or positioning - since it has an arm on the shaft coming out of the top that connects to the bar assembly. As far as I can tell, there is no power to it unless it's connected internally (inside the casting where I can't see it till I open it up). Forward and off-side of that (if I am recalling correctly) is what looks like the actual gear box since the pto connects to it, not the the other circular housing, and this connects to the pitman, which is square cross-section made of wood. That's pretty rough, but starts to give you an idea. At worst, I'll sketch what I've got, and post that as a pic and se if that helps. My tractor (MF35) does have a height adjustment on one of the lift arms, so I can compensate some with that, but some of the issues you raise concern me. Starts to sound like my ignorance might have bought me a white elephant. Thanks for your reply.
