Needed: Illustration of drawbar unit for 30 series JD tractor
Don
01-17-2003 16:23:35
I have a JD 630 tractor that I am trying to attach a semi mount sickle bar mower to. The mower has 2 flat bars which bolt to a drawbar unit. Does anyone know where I can find an illustration of what one of these drawbar units looke like for JD tractors? I am going to make one up to attach to the tractor.
ET
01-19-2003 07:03:21
 Re: Needed: Illustration of drawbar unit for 30 series JD tractor in reply to Don, 01-17-2003 16:23:35
The flat bar is 11 3/4" long and 3" wide by 5/8" thick. The mower atatching pin is 1 3/4" in diamiter and welded to the base plate at one end. The center of the pin is 2" from the lower edge of the plate and 1 1/4" ahead of the rear edge of the plate. There are 3 mounting holes in the plate all for 5/8" bolts. The front one on the end away from the large pin is centered on the plate. It is a sloted hole with the first center 7/8" from the end, the center of the other end of the slot is 1 11/16" from the end. That sloted hole is for a carrige bolt. The other 2 holes are countersunk for 5/8" plow bolts. There location is, the upper one is 1" from the top(thats the edge the big pin is offset to)and 6 5/8" back from the front edge. The other hole is 3/4" up from the bottom edge and 9 1/4" back from the front edge. I hope this helps let me know.
