Need help to identify plates for JD 494A planter
Scott
01-15-2003 17:27:40
I have a few sets of plates for my JD 494A planter that I need to figure out what they are for. H-1255-- H-1268B And some Lustran plates numbered B1-16X -- B25-16 -- B150-16 any help would be appreciated
kydavid
01-15-2003 19:47:06
 Re: Need help to identify plates for JD 494A planter in reply to Scott, 01-15-2003 17:27:40
I used to have one of those planters. On the back of the seed corn bag (there usually is) is a table for which plate to use with the particular corn for the particular popuation. At least there was on pioneer 10 yrs ago. Think most of the 3165 I got used a B-10 or a B-16
paul
01-15-2003 20:16:30
 Re: Re: Need help to identify plates for JD 494A planter in reply to kydavid, 01-15-2003 19:47:06
Dad saved a couple of those old bags to cross-reference things. The new bags don't have the chart any more. I don't need it either, with the JD finger pickup I have now. But I always wanted to write those charts down somewhere, just because..... Our planter was so old (a Case 4-row with checking option) that we had to go through 2 bags of charts to cross-reference what worked in what plate...
--->Paul
David B
01-15-2003 18:33:36
I don't rember the size of plates to use on the graded corn but a good seed dealer should have a chart with the size of kernals and the plate to be used. I think the number 16 on the is for 16 cell. They could be had in 16 or 24 cell, I used the 24 cell because you can slow the speed down to 2/3 of the 16 cell and plant the same population. Need to use the right seed spacing chart for each plate.
Larry
01-17-2003 08:01:16
 Re: Re: Need help to identify plates for JD 494A planter in reply to David B, 01-15-2003 18:33:36
You are correct. The 16 stands for a 16 cell. Most people use the 24 cell plate. The B1 is a very common med. round in a plastic plate or was the 10853 in a steel plate. The med. flat was a F7 in plastic or 1302 in steel. If the plastic plates are old they had a tendency to wear over time and became inaccurate. They are so cheap I would get a new set of plastic from your seed dealer to match the size seed you purchase. Most companies still sell a certain amount of graded seed. Remember, many people like med. round for planting accuracy but actually the med. flat has the best germ qualities.
