Need opinion on Oliver semi mount sickle mower
Don
01-15-2003 15:27:48
I am looking for more information on an Oliver semi mount sickle mower. First of all can it be attached directly to the drawbar of a JD 630 tractor. Were these good quality mowers in their day? How much would a good condition working model sell for today? Since Oliver no longer produces equipment can parts such as rock guards and cutter knives still be obtained for these mowers?
Charles Wray
01-15-2003 17:18:47
 Re: Need opinion on Oliver semi mount sickle mower in reply to Don, 01-15-2003 15:27:48
I use a 3point hitch #356 works very well. Paid $150 for it. A semi mount here in Pa can range from $100 to $300 depending on the condition. Model's 22 and 87 bolt directly to the drawer and it should work well on your JD 630. The 3 point hitch units are heavy and require a sturdy tractor. I bought mine from a man who tried to used in a small popper JD tractor (don't know the model) hitch was not sturdy enough broke the pto universal. I use mine on a Oliver 1550. Parts still can be ordered most companies use the same size. Any tractor supply should be able to find the pieces needed. Order a operator's and parts book if one doesn't come with the mower this will help with adjustments, parts and tractor connections. Good luck.
Charles Wray
01-15-2003 17:13:44
