JD plow
David Church
01-11-2003 08:53:26
Trying to identify this plow setup.
Number on Bottom is N?-314-N?
Number on Shin 8195-A
Number on Share BC-454 (Throw away share)
Which plow and bottom set up do I have?
Bob Collins
01-12-2003 13:28:49
 Re: JD plow in reply to David Church, 01-11-2003 08:53:26
You can determine the bottom assembly designation from these numbers, but not what the plow itself is. It is like trying to identify an electric drill by looking at the number on the drill bit. Lots of different bottoms were available for each plow to suit the soil conditions, and most would fit lots of different plow models. To identify your plow you need to look at the plow itself and post a description. Things to look for are beam numbers if any are stamped into top of beams, casting numbers, lift mechanism, hydraulics?, levers, cranks, adjustments etc. :)
52BMAN
01-12-2003 10:41:53
If your plow is a 2 bottom, them you could have a John Deere NO. 44 plow. The number on your moldboards is either NPG314, NA314 or MP314. The share and shin numbers match close to this plow, but I'm not 100% sure.
