Need Advice on Hay Implement Selection
Uncle Dave
01-08-2003 08:25:40
I plan to start putting up Brome grass hay this season.Approx 140 ac). I need help selecting the right implements. I have a JD2010-D with new motor (46hp). Do you think this tractor can comfortably handle a 14' pull behind swather? Do you think it could bale hay from the windrows made by a 14' swather? How about a bale wagon? Think this tractor could pull a bale wagon? Anyone know of a bale wagon that can stack a "tie" bale on every layer? Better still, what would you guys reccomend for my situation?
Thanks
Big red 460 diesel
01-09-2003 17:48:59
 Re: Need Advice on Hay Implement Selection in reply to Uncle Dave, 01-08-2003 08:25:40
I would say that you would need at least 75hp to power that mower succesfuly. I pull a 9ft case haybine with a MF275 about 75hp and in south east MI were we have alfalfa timothy and clover it really makes the tractor grunt on the 1st cutting of the year. But I still would say you need at least 75hp to power a mower that big.
Chris L
01-08-2003 19:35:37
140 acres sounds like a lot - once a year or twice or more?
mowing and raking is not out of the question - then your tractor is big enough.....
I have a sickle mower - cheap and slow and high maintenance - With that much I would probably go for a disc mower since ground speed can be so much faster -
Chris L
01-08-2003 19:30:26
Chris L
01-08-2003 19:29:57
Jimmy C
01-08-2003 12:28:33
I would say your JD 2010D will not be up to the job, too small, and in my opinion, the worst
tractor ever made. You'll need 65hp up to use the
14' swather efficiently. Less power will work but
the ground speed would have to drop. The 2010
can easily handle a 9' mo/co or 7' disc mower.
paul
01-08-2003 11:07:47
I'd think the swather would want a bit more power & heavier tractor to 'anchor' it.
A regular small-square baler can be pulled by 46hp. Maybe you would be happier with a bit more, but I rake 21' of alfalfa together for my 270 NH baler & 36hp 300 IH tractor.
140 acres sounds like a lot, I'd want a bigger tractor to keep up, but I'm in alfalfa country where you get 3-4 cuttings and the first one is very heavy.
--->Paul
david
01-08-2003 10:44:59
2010 on a 14' swather, probably, be a handful. I use an 8' disc mower, and cut more than 140 acres. As far as baling, yes. That's about what I put in a windrow for small squares. As far as staking a tie tier on every tier, I'm not sure why. I've got a 1034 NH and usually use a tie tier on 4 and 2 wide cap on the stack. You can tie and reverse tie with either a 1033 or 1034.
David
