JD #44 plow
Mark in Mississ
01-05-2003 08:24:24
I would like someone who has access to a #44 plow on steel with trip rope to send me the measurements of the flat bar that attatches the trip wheel to the lifting bracket assy. Mine is missing and and futile attempts at making one result in it not working too smoothly at all! Any help will get me to plowing soon , Thanx in advance for any and all responces. Mark
Blaine
01-05-2003 14:51:42
 Re: JD #44 plow in reply to Mark in Mississippi, 01-05-2003 08:24:24
Hi,Mark I'm going to try to give you measurements for part no. 28186A-Lift Bar. Hope this is the part you are talking about. It is 22-1/4 inches long, 1-1/2 inches wide and 1/2 inch thick.One end flares out to a circle that is 2-1/8 inches wide.In this circle is a 1-1/8 inch hole,from center of this hole go 18-1/2 inches to center of a 25/32 inch hole,than go another 1-1/2 inches to center of another 25/32 inch hole.Hope this helps. Have fun,Blaine
Mark in Mississippi
01-08-2003 09:48:50
 Re: Re: JD #44 plow in reply to Blaine, 01-05-2003 14:51:42
You just don't know how much this info is appreciated !!!!! Thanx ever so much. Now it's off to the steel yard ta get what I need. Mark
