Mounted plow setup
Spud Pavey
12-31-2002 13:44:26
Can anyone explan the proper way to set adjust a allis chalmer 2 bottom mounted plow . I have this plow on a 1952 WD-45 and I cant seem to get it in the ground deep enough. It seems to keep wanting to ride back up. Any info appriciated.
Scott
01-02-2003 09:43:10
 Re: Mounted plow setup in reply to Spud Pavey, 12-31-2002 13:44:26
Your plow should be adjustable to let the front dig in more. If the shares aren't worn out, tip the front of the plow down more. When setting on ground, both botttoms should hit ground about the same time....it'll be close enough to get you started. When plowing, the frame of the plow should set level side to side as well
Spud Pavey
01-01-2003 08:28:48
Thanks for the info. As soon as it freezes again I will check all of this out.
larry
01-01-2003 06:33:03
also check traction boster by battery box if set to light will pop out if needed chain weight on plow
Ron
12-31-2002 18:24:28
First.....are the shares new or worn.??
If they are worn out, it won't go in the ground, and may just come out if you do get it in.... You can tell, be feeling under the share...the share should reach out far enough that the bolts don't touch the ground when the plow is in the ground... I don't have a 2-bottom....I do have a 3..... If there is a crank (adjustment) on the top of the plow....screwing it IN, lowers the plowing depth...
