JD # 44 plow points
Dave in Ohio
12-30-2002 23:38:54
Can anyone give me the part number for the plow points for a Model 44 JD plow.
Thanks--Dave
Bob Collins
12-31-2002 06:28:30
 Re: JD # 44 plow points in reply to Dave in Ohio, 12-30-2002 23:38:54
Dave, this is a common question with no answer. A #44 plow could and was equipped with any of many different plow bottom assemblies. You need to determine which bottom you have then a point part number can be found. To determine your bottom designation, you may need to get a copy of the " plow bottoms" parts catalog and start comparing any numbers you can find on moldboards, shins, frogs etc. Some John Deere parts men are familiar with these and can be very helpful, others not so much. Sorry this gets complicated, but it's the only way I know to be sure what you get, fits. Bob
Bob Collins
12-31-2002 06:34:08
 Re: Re: JD # 44 plow points in reply to Bob Collins, 12-31-2002 06:28:30
I forgot to add that if you are very lucky, the number might be readable where it is painted on the back of the moldboard. Typically it is 2 or 3 letters and 3 numbers such as: HS316 or NGP 214.Cross your fingers and look closely.
