New holland model 14 wagon gear
mark ct
12-30-2002 05:06:15
i just purchased an old new holland wagon gear for 200 bucks. on the tag it say new holland model 14. does anyone know what tonnage this model is rated for? i am planning to put a 16 ft hay wagon body on it.
Scott
12-30-2002 15:36:31
 Re: new holland model 14 wagon gear in reply to mark ct, 12-30-2002 05:06:15
Only 4 tons, when that was made they only used small flat beds for stacking bales.
mark ct
12-30-2002 20:00:57
 Re: Re: new holland model 14 wagon gear in reply to Scott, 12-30-2002 15:36:31
so what size body would you recommend for this tonnage of gear, i will be using it with a kicker not stacking the bales usualy. the running gear measures about 11 ft from axle to axle right now so i thought that about a 16 ft body would work out well or do you think i could go longer if i extended the pipe in the center?
Tim(nj)
12-30-2002 20:30:15
 Re: Re: Re: new holland model 14 wagon gear in reply to mark ct, 12-30-2002 20:00:57
I have 7'x7'x16' on my two 4-ton JD gears. If you make the pole longer, it may get bent, which happened to a Gehl gear that came under an 8'x8'x18' that I bought at an auction. If I stack a 16' wagon (sometimes I have to get as much hay as possible on each of 5 wagons so as not to lose any to bad weather) I get 130 bales on there, which at 50 lbs. per bale is 6500 lbs., plus the weight of the rack, is about all you want on the gear. The same wagon will hold maybe 90 bales kicked in a pile.
mark ct
12-31-2002 06:31:09
 Re: Re: Re: Re: new holland model 14 wagon gear in reply to Tim(nj), 12-30-2002 20:30:15
just outa curiosity, where in nj are you tim. i bought this wagon gear from a guy in bordentown, right near trenton.
Tim(nj)
12-31-2002 06:44:20
 Re: Re: Re: Re: Re: new holland model 14 wagon gear in reply to mark ct, 12-31-2002 06:31:09
30 miles north of Trenton.
mark ct
12-30-2002 19:58:38
