It Is Alive!
steve belcher
12-29-2002 18:05:42
As you may remember, I recently brought home a McCormick #7 mower. After making a new tongue, and temporary pitman arm, I selected the best out of five very rusty cutter bars. It actually cuts grass! Now for the question, what is the proper way to connect the pitman to the cutter? I'm not even gonna tell how I did it.
Thanks in advance,
Steve Belcher, somewhere in Va.
moonlite
12-30-2002 08:43:58
 Re: It Is Alive! in reply to steve belcher, 12-29-2002 18:05:42
Please tell us how you did it!!!!
steve belcher
12-30-2002 15:51:34
 Re: Re: It Is Alive! in reply to moonlite, 12-30-2002 08:43:58
I connected it by using some 1" flat bar bolted to both sides of the pitman and to each side of the ball, with a small bolt to connect it. Kinda like the ball/socket pic, just not as glamorous.
steve
paul
12-30-2002 18:54:35
 Re: Re: Re: It Is Alive! in reply to steve belcher, 12-30-2002 15:51:34
Pretty good for testing.
The bolt(s) in the strap going into the ball will _not_ last long, as the vibration/hammering will get to them & whittle/shear them off.
But, you qualify as an ace old machinery tinkerer. :) Good job.
Without the proper socket parts on the bottom, be _real_ careful tilting that blade up vertical - if you can do that, transport position. On some models it is possible for the blade to drop out the bottom without the retaining ear. As well, you _always_ have to watch your fingers & keep them away from the blades when picking up the bar to vertical, as it will slip down & slice fingers off.
Disclaimer: I'm not responsible for any problems my simple thoughts cause. Everybody's on their own.
--->Paul
paul
12-30-2002 09:46:25
Yea, me too! ;)
Ball & socket, if you can't find or afford original, some farm supply stores carry some of the generic parts, you can adapt to make it work. (There is a green JD socket on my red 501 Ford mower...) But it needs the ball & socket, needs to be able to move in all directions or it will just wear out or break anything else like a bolt, etc. in no time flat.
Disclaimer: Not responsible for misuse or errors in this info.
--->Paul
Old Iron
12-30-2002 07:34:15
third party image
Steve,
Here is a scan from my #7 manual on how to connect and disconnect the pitmen. Hope it helps you out.
My 2 bits worth,
Old Iron
marlowe
12-29-2002 18:49:10
i think they used a ball and socket the ball was on the sickle and the socket at the end of the pitman thata the way most are
