Johndeere #38 sickle bar mower
jerry b
12-28-2002 08:11:30
question: does someone out there know what tractor this #38 mower was made for and what series of john deere tractors this will work with. thank you very much in advance. jerry b.
Craig
12-29-2002 11:24:59
 Re: johndeere #38 sickle bar mower in reply to jerry b, 12-28-2002 08:11:30
Back in the mowers day JD supplied mounts for many makes and models of tractors that were popular at that time. If JD did not have a ready made mount for a particular tractor you needed to make your own from "cut to fit" parts from JD or fabricate your own mount or a combination of the above. What make and model tractor are you interested in mounting the 38 mower on?
jerry b.
12-30-2002 09:32:10
 Re: Re: johndeere #38 sickle bar mower in reply to Craig, 12-29-2002 11:24:59
craig i tried to use the #38 jd mower on a 601 ford; i have the mount, but the ford does not have the down pressure on the drawer bar and the weight of the mower tilts it to the right side, but that's not a real problem i can fix that with a fixed draw bar. i don't have a remote hydraulics on the 601 and it is too expensive to add the selector valve, so i am going to get another tractor anyway, probably a 4020 john deere with a remote hydraulic connection, but thanks for answering my question so kindly. jerry b.
steve
12-30-2002 13:15:18
 Re: Re: Re: johndeere #38 sickle bar mower in reply to jerry b., 12-30-2002 09:32:10
I have the mount to put the #38 mower on the 4020 if you need it get back to me.I have used it a lot oh the 4010 and 4020.Thanks Steve
Rick
12-29-2002 04:38:46
I will sell an operators manual that came with 37&38 mower we had if someone wants it.
jerry b
12-30-2002 09:41:54
 Re: Re: johndeere #38 sickle bar mower in reply to Rick, 12-29-2002 04:38:46
rick, how much do you want for the #38 sickel bar mower operator's manual. how many pages does it contain. let me know. thanks. jerry b.
Rick
12-31-2002 17:02:12
 Re: Re: Re: johndeere #38 sickle bar mower in reply to jerry b, 12-30-2002 09:41:54
Jerry, the mower book I have is called predelivery instructions. Gives all adjustments and how to hook on to different tractors. 37,38 and 39 mowers (21 pages) Sell for $25.00 plus postage & handling. It is all still together not torn up.
Rick
12-31-2002 17:01:07
Rick
12-29-2002 04:38:41
Rick
12-29-2002 04:38:03
pappy
12-28-2002 09:35:00
I use mine with a 2510,they can be used with any tractor,but you need the quick attatch knobs to mount on your tractor.I had to cut an inch off each end of the pto shaft to allow for play.Check with your JD dealer. happy mowing , pappy
