Meanings of terms used in estate sale lists
John van Willig
12-26-2002 09:20:21
I am working on a book about the history of farming in Central Kentucky. In the estate sale lists from the 1920s, I have found references to cutter plows, land plows, and hillside plows. All might appear on the same list. I sure what hillside plows are but I have not been able to figure out what people meant by "cutter" and "land" plows. At that time these would be horse drawn. Any ideas?
Leroy
12-27-2002 16:44:09
 Re: Meanings of terms used in estate sale lists in reply to John van Willigen, 12-26-2002 09:20:21
Cutter I would guess is what Grandpa called a stumpjumper for use in new cleared land still full of roots, had a cutter knife from the beabto the point of the share that would cause the plow when it hit a berried stump to raise the plow to slide over the stump instead of trying to jam into the stump or under a root ant that you would have to hook to the backside of the plow to pull it out (Unjam) it. Land should be flat land instead of hillside.
