Grain drills
dan in parma
12-24-2002 06:05:43
witch drill's work better jd or ihc? gang press wheels or press wheels attached to opener's? need opinions! thanks
Rick
01-05-2003 18:47:24
 Re: grain drills in reply to dan in parma, 12-24-2002 06:05:43
Drills. You are really not asking which is best in press wheels. You are comparing depth wheels with press wheels. The wheel on seed openers will not allow narrow spacing if you are doing mall seed. About 10inches narrow as you can go. The press wheels behind on some drills still control depth to some degree along with firming seed. I like 2 inch press wheels on 7.5" spacing for what I do. I know where their is a very usable JD 8200 series drill,with small seed,drag chains instead of press wheels for $850.00. He used it last season to do beans.
dan
01-08-2003 15:27:49
 Re: Re: grain drills in reply to Rick, 01-05-2003 18:47:24
thanks for the info. I have a jd 450 grain drill with seeder and gang press wheels. they tell me that the other type of press wheels are better don't what they are called? what i am having trouble with is on the ends not many plants but in the center plants just fine (maybe discing too much) wondering if i should look for a different drill?
dan
01-08-2003 15:25:55
dan
01-08-2003 15:13:15
dan
01-08-2003 15:08:14
dan
01-08-2003 15:01:19
dan
01-08-2003 15:30:34
 Re: Re: Re: grain drills in reply to dan, 01-08-2003 15:01:19
sorry about all the posts was having trouble!
dan
01-08-2003 14:56:18
dan
01-08-2003 14:52:38
dan
01-08-2003 14:49:03
dan
01-08-2003 14:44:02
Rick
12-25-2002 09:02:13
I have run the Deere drill,515 with carts,750 model,and also have run the IH with coulter cart. I like best the one I have now which is Marliss drill on coulter cart. Has better flutes and alot better way of setting them. Box cleans out alot better. If deere I would stay with 515 and cart over 750. Just my 2cents.
dan in parma
12-28-2002 09:12:45
 Re: Re: grain drills in reply to Rick, 12-25-2002 09:02:13
thank you for your comment's but what Iam looking for is opinion's on witch press wheels are better gang press wheels or the ones that are mounted to the openers(depth gauge wheels?) convenional drill not notill. jd or ihc? Thanks again!
dan in parma
12-28-2002 09:08:42
Rick
12-25-2002 09:01:24
galen
12-24-2002 10:05:36
What type of soil. What will you be putting in with it, wheat, milo, beans. Do you intend to have grass seed on it,
dan in parma
12-24-2002 11:13:31
 Re: Re: grain drills in reply to galen , 12-24-2002 10:05:36
we have heavy to light soil&we plant mostly beans could have a grass seeder on it also would like it to have markers
