What are Baker fans used for?
Dan
12-20-2002 06:10:39
Never seen one up close, only on film or tape so I am curious as to thier application. Thanks.
Larry
12-20-2002 10:07:43
 Re: What are Baker fans used for? in reply to Dan, 12-20-2002 06:10:39
As I understand it the Baker fan was developed by the Baker Steam Engine Co. in order to put a constant load on the steam engines in order to set the steam govenor to the right RPM.
jim
12-20-2002 07:40:40
As far as I'm aware , the Baker Fans were the predeceser of the test dyno you see at your local farm dealership. They are also used to put a load on the tractor in order to adjust the carb and timing. Fully engaged, they can bring a tractor to its knees very quickly.
mj
12-20-2002 08:28:12
 Re: Re: What are Baker fans used for? in reply to jim, 12-20-2002 07:40:40
It's a real experience to see a steamer "pulling the fan" after sunset; smoke, steam, sparks and the sounds to go with it! I haven't been to Mt. Pleasant for the Reunion since the seventies but that was the first sight we saw after we arrived late one evening. It was a spectacle I'll never forget! Like you said, they just kept loading the fan until the tractor could do no more; what a sight.
mj
12-20-2002 08:25:28
mj
12-20-2002 08:24:18
mj
12-20-2002 08:23:14
It's a real experience to see a steamer "pulling the fan" after sunset; smoke, steam, sparks and the sounds to go with it! I haven't been to Mt. Pleasant for the Reunion since the seventies but that was the first sight we saw after we arrived late one evening. It was a spectiacle I'll never forget! Like you said, they just kept loading the fan until the tractor could do no more; what a sight.
mj
12-20-2002 08:29:56
 Re: Re: Re: What are Baker fans used for? in reply to mj, 12-20-2002 08:23:14
That's special! I think my browser needs a ring job!!!!
Steamer
12-20-2002 11:48:05
 Re: Re: Re: Re: What are Baker fans used for? in reply to mj, 12-20-2002 08:29:56
No I think you were just "loading" your browser like they load up those baker fans:=)
Steamer
12-20-2002 11:47:26
