Depends on what shape your pasture is in to begin with. If you've got fair sod coverage and you're determined to do something, you can do a couple passes with a spring harrow to loosen things up and broadcast seed....let nature do the rest. (less is often better here..) If It's in really bad shape, and you want it to be a 'first class pasture" disk at right angles till you've got it flattened and the soil is fiine & even. Harrow if you need to, Then you can broadcast seed followed by a 2 passes with light harrow at rt angles and roll it (or use a seed drill followed by a roller). Plan on this when there's going to be moisture to get the seed going. Wait about 6 to 9 months to get good root structure before you mess around out there again. (This means no critters) After that, if you don't abuse it and keep the thistle out (at least around here) you won't have to fool with it again for a long time. Back to your original question.... A complete setup... disk, spring harrow, broadcast seeder (recommend it 'cause you can use most of them for pellitized fertilizer too)..., roller. Depending on what you want to do with all that grass... If you're gonna make hay, Flail type mower & rake or haybine, Baler (probably rectangular for a smaller farm)... or hire the baling out. Often done for "shares"... The labor and liability laws have made it nearly impossible to hire high school kids... (my haybucking carreer ended about 30 years ago !) Your ag agent can give recommendation for seed mixtures for your area. I think there was (still) even a program where the soil conservation service would give you enough seed to repasture 3 acres a year ....
