Which is stronger, a 3-pt or a loader?
James
12-18-2002 19:03:17
I was looking at a posthole digger that would mount to the front-end-loader of my 4020. (model 720 loader)I was wondering if the hydraulics on the loader were as strong or possibly stronger that on my 3-pt. Being able to use the down pressure of the loader would be nice in our hard soil but I don't want to make an anchor out of the auger bit.
Thanks, James
Danuser D8
12-18-2002 19:25:45
 Re: Which is stronger, a 3-pt or a loader? in reply to James, 12-18-2002 19:03:17
Check out Danuser.com The Danuser D8 is one awesome unit and the down pressure kit adds 500 lbs of pressure to the weight of the unit. They also make a D20/40 model that has a 500lb down pressure kit. These are really nice and will last forever. The front loader with a hydraulic auger will generally "push" down harder and is "stronger" but it is also much more expensive and more complicated to attach/remove. Unless you are a commercial operator and doing "holes" for a living I would go with the 3 point. Danuser or Bush Hog or even a cheapo.
Robert in W. Mi.
12-19-2002 06:47:55
 Re: Re: Which is stronger, a 3-pt or a loader? in reply to Danuser D8, 12-18-2002 19:25:45
I bought a cheapo PTO post hole digger and found there's a "big" difference in how they are designed and work compared to a better digger. My brother bought a Bush Hog digger, and it dug so much better in tough conditions i couldn't believe it. I now have a BH digger, and it's the bare mininum post hole digger i'd ever buy. (my ground isn't sand and i have stones) The cheaper diggers have smaller cheaper gear boxes, and augers that aren't nearly as aggressive as the better units. I like haveing the digger on the PTO, and then use the loader bucket to carry all the other things i need, like post ect.. Another thing, the PTO has a lot more lifting power than the loader to pull the auger in wet heavy soils, expecially when there's roots involved. Robert
