John deere 54 manure spreader
ton rietveld
12-11-2002 21:08:59
A few weeks ago our spreader broke down. A spring clip in the conveyorbelt gearbox came off an axle and caused misalignment of the worm gear and ring gear. This must have happened a long time ago and slowly since then the worm gear ate all 50 teeth of the ring gear until it stopped turning. This spreader was built in the 70's. The computer at the local John Deere dealer here in Southern Oregon considers the ring gear a piece of vintage ag equipment, (that should stay on the shelf, unless you pay $630.00 for it) I would like to fix it and prevent it from happening again. Is this a common problem with this gearbox and what can I do to prevent it? Also is there a way to find this gear elswhere? This seems to be the only JD 54 manurespreader in all of Oregon?
