Both of my tractors came to me with loaders, the 641D with a tractor hydraulic trip loader and the 851 with a full hydraulic with a front pump. I looked at a nice DuAll full hydraulic that had been on a Massey that I could have bought for $750. It had not been used for several years and still is sitting in my neighbors yard. He said he saw it operate and it didn't leak, but it would have needed modification to fit a Ford. I got the 851 instead. I have over $500 in rebuilding one main cylinder--the gland was broken and it leaked real bad and had a bad rod--and a couple of new hoses. I still have to reseal one of the bucket cylinders and some of the hoses look pretty weather checked, but will be OK for now. One of the main cylinders on the trip loader was leaking pretty bad and the shop wanted about $300 to rebuild it. I just resealed it for about $40 and it is doing OK, but I know that it will need attention sometime. I also need to do a lot of welding on the bucket. It is cracked in several places. Maybe I have tried to work it harder than it was designed for. Anyway it needs reinforcing. I like the smaller bucket for some things, like moving and picking rocks. In my opinion, a full hydraulic loader operating from a front pump, that is in good operating shape adds about $1000 of value to a Ford tractor. Simple reseals are fairly cheap to do yourself, but having a cylinder rebuilt (and guaranteed) is very expensive. Hoses can really add up quickly, if you have to replace them and valving is very expensive to replace. I thought about a front pump for the trip loader, but it would have ended up costing at least $500 to get it working, using all new parts. If you ever operate a hundred series Ford with a tractor hydraulic loader, you will find that it is very slow. But you can get used to this--a tractor hydraulic loader is a lot better than no loader at all. I use my loaders more than any of my other implements, almost every time I start the tractors. I would be very cautious about paying much for a loader than I could not see operate. There is often a good reason someone takes a loader off the tractor, as that job is a lot of work. A wounded loader can become a real money pit. But have you priced new loaders? Good luck.
