JD Plow with 439/440 beams
Dennis K.
12-03-2002 10:35:10
Looking for additional information on an old John Deere 2-14 plow. Some of the part numbers are: 439 & 440 beams, D447A land wheel, D450A clutch drum, D441A rear axle pivot and D440A rear axle sleeve. I am in the process of rebushing the land wheel/axle and repairing other parts. Is a parts manual or some other assembly diagram available? Right now I need a assembly diagram for the land wheel axle (size of pins, washers used, ...). Also, where could I find a couple of 14-inch plow bottoms and land slides? Thanks,
Bob Collins
12-04-2002 16:19:24
 Re: JD Plow with 439/440 beams in reply to Dennis K., 12-03-2002 10:35:10
Dennis, You have a number 5 or possibly #6 plow they were made before John Deere printed individual parts catalogs. Back then the dealer had a plow works catalog with lists of numbers and descriptions but no blow-up pictures, I would get a parts catalog for the 5C and 6C plow as a guide, there are differences but it is a start, try to find a set-up and operators manual on ebay or some swap meet, that should be of some help. The plow works catalog is fun to have and there is a bunch of info if you care to dig it out, but most guys who have one want a lot for it. I always liked that D447a cast spoke land wheel, good luck with your plow. Oh, I looks like they were replaced by the 5A in 1920, so yours must be old.
Dennis K.
12-05-2002 06:25:41
 Re: Re: JD Plow with 439/440 beams in reply to Bob Collins, 12-04-2002 16:19:24
Bob, What is the difference between a No. 5 and a No. 6 plow? I did get the PC387 parts catalog for the 5C & 6C plow. I also got two 5A setup and operating manuals (DIR-140 from JD publications and a DIR-313? from ebay). My goal is to get the plow working by early spring so I can take a picture of it plowing the garden (at least one pass). Then I might sandblast and paint it. Thanks,
Bob Collins
12-05-2002 08:30:21
 Re: Re: Re: JD Plow with 439/440 beams in reply to Dennis K., 12-05-2002 06:25:41
Dennis, I woke up this morning and thought you did say it was 2-14" plow so that makes it a #5. The 5 could be a 2 or 3 bottom but the #6 was a 3 or 4 bottom plow. Sorry for the confusion. Bob
