Who farms with the oldest tractors Equip
Okla/Kans Bill
12-01-2002 14:46:36
I saw a nic calledold time farmer and he said he was going to use his Model R JD in the 50s. Well I used a 34 CC Case for around 20 yrs before I also got a 37 F-30 Farmall. This year I really splurged and went modern with a 48 Cub Farmall, but I mostly use it with its belly mower. Alla my equip with the eception of the bailer 60 and sprayer ?is pre 40s. is there anybody else farming with tractors and equip this old exclusivily?
joe from WI
12-09-2002 15:07:21
 Re: Re: who farms with the oldest tractors Equip in reply to Bret, 12-09-2002 04:55:40
Bret, believe it or not afriend of mine still uses surge buckets and milk cans. Is he crazy or crazy like a fox? With all the Amish around here there are still a few can haulers. He's told me why spend big money to replace something that his dad paid for that still works just fine. joe...
Bret
12-10-2002 05:04:01
 Re: Re: Re: who farms with the oldest tractors Equip in reply to joe from WI, 12-09-2002 15:07:21
Yup, I use Universal Bucket milkers. I don't ship milk, but it's there if I need it. I know of quite a few guys around here that still use bucket milkers, even the big guys do for fresh cows and sick ones. Someone contacted me off board- and yes I use the binder for real. I do about 5 acres of oats for myself each year, or try to anyway. Between the wind here and damp weather, you can bind and let them ripen in the stook and get a lot more per acre. My off farm job gets in the way of a lot of my projects here, but in 4 years I can devote all my time to it.
joe from WI
12-11-2002 07:42:08
 Re: Re: Re: Re: who farms with the oldest tractors Equip in reply to Bret, 12-10-2002 05:04:01
RIGHT ON BRET!!! Let'em LAUGH!! Bigger, Newer,Faster, Shinyer don't necessarily MEAN BETTER!!!!! !! joe
joe from WI
12-11-2002 07:41:00
joe from WI
12-08-2002 18:15:00
 Re: who farms with the oldest tractors Equip in reply to Okla/Kans Bill, 12-01-2002 14:46:36
59'IH 560, 54'AC WD45, 38 AC B, NH super69 hayliner, IH #46 until this past summer, NH#477 haybine, JD#5 and a MCmk crimper as a backup, JD#30 combine, JD CC digger, IH 8'disc, AC 3-14 snp cpl plow, 2-14 wd pck up plow, JD #594 rake on steel, 8' IH drill, Prehistoric( it says 1912 on it) cultipacker, JD #40 spreader,pre 1940 three section LaCrosse spring tooth harrow, Gehl Mix all Grinder/Hammermill, buzz saw for the "B" for firewood. I for now can buy corn cheaper than I can raise it.Joe...
elaine
12-03-2002 13:11:04
Old equipment is standard fare on our farm. I bale hay for my 83 year old dad and use our 55 massey ferguson tractor pulling a Ford 501 sickle mower. we rake with a horse rake , but use the tractor. and bale with an allis chalmers rotobaler. I get alot of work done with the godd old equipment and wouldn't have it any other way. thanks for asking.
elaine
12-03-2002 13:10:14
elaine
12-03-2002 13:10:00
Okla/Kans Bill
12-03-2002 13:46:24
 Re: Re: who farms with the oldest tractors Equip in reply to elaine, 12-03-2002 13:10:00
sounds good, but still your stuff is overall alot newer than mine.My dads 83 too, my moms 94. They still live on the farm. Dad has cows there,milked a cow up till around 4 yrs ago just got rid of his chickens this year. Mom canned 200qt 2 yrs ago. Take care
Green Envy
12-02-2002 16:06:18
I know a guy who farms with a JD R and a IH 141 combine. He has no off farm jobs either.
M R
12-02-2002 15:50:43
Does anybody use steel wheel tractors to farm with? What are they used for?
Okla/Kans Bill
12-02-2002 17:10:58
 Re: Re: who farms with the oldest tractors Equip in reply to M R, 12-02-2002 15:50:43
My 34 CC Case and 37 F-30 Farmall origionally came out on steel wheels. They were supersieded (by farmer demand, and as an extra option) on later tractors> Both of mine came out on factory rubber . Alot of the steel rims was cut off and rubber wheel rims inserted in there place. In WW 11 tractors again went on steel due to a rubber shortage. I have even seen Ford 2N 8N on rubber long with AC C tractors. The only good thing about them is they didt go flat. The skeliton grip steel wheels was bad in soft ground or gopher infested ground as my dad has told me. If they slipped, ytou dropped like a rock
Tim(nj)
12-02-2002 17:04:02
Nursery next to me uses an F12 Farmall on steel with cultivators and side dressers in the young shrubs. Why? Because it's paid for many many times over and doesn't cost a lot to keep running, so they tell me.
TomH
12-02-2002 16:58:50
Steel wheels are used a lot by Amish and Old Order Mennonites around here. I don't quite follow the philosophy; they have rubber tires on their buggies and bicycles, but put steel wheels on the tractors and skid loaders. One even plows his fields with a tracked bulldozer but uses a steel wheeled (and fairly new) John Deere tractor to lay the black plastic mulch for strawberries.
Brian M.
12-02-2002 06:17:45
I have a 44 Farmall H with a JD #5 mower, an old rust covered side delivery rake (David Brown I think), a New Idea hay crimper, NH Model 66 baler, and an 8 ft Dunam disk. I will put that old hay rake up against any new rake!!!
Kelly C
12-02-2002 06:39:13
 Re: Re: who farms with the oldest tractors Equip in reply to Brian M., 12-02-2002 06:17:45
Looks just about like my set up.
Farmall H, JD #5 mower, New Holland 68, MN side hay rake. Not sure of the brand Hay rack I have.
I am not sure I could be called a farmer yet though.
Ralph
12-01-2002 22:54:01
I still use a F12 with a 501 sickle mower to mow hay with.
Ernie Bob
12-01-2002 20:58:16
On our hay farming operation we use a 1956 400 Farmall, a 1955 300 Farmall, a 1955 200 Farmall and a 1954 SMTA. Our swather is a mid 60's NH, 60's NH hay rake, early 70's baler and early 70's bale wagon. Everything works real well, course we do plenty of maintenance on the winter.
chief 83
12-01-2002 19:32:07
I use a '48N and a '48 Cub Farmall for almost everything. I cut hay with a Ford 501 sickle bar and rake with a Ferguson side delivery. I go modern when it comes to baling. JD with a 315 New Holland baler. I guess the baler is now old enough to vote!
david
12-01-2002 19:03:12
When I started farming on my own (right at the end of the early 80's bust) I used old stuff. Saw a lot of people I admired and respected go broke trying to pay for a lot of high $ rolling stock. Most of what I had was "painted" rust, could just barely tell the brand. I still use older tractors (oldest now are a 1976 Ford 7600 and 1410 Case) newest until a couple of weeks ago was an 84 7710 Ford (bought a '92 7610 Ford). Have managed to get a pretty new line-up of equipment (all 90's or later except a 336 JD square baler and a 1034 NH stackliner). Decided it was better to focus on what I do well (hay; 10,000 squares and 1000 rolls plus 100 each momma cows and mares) and sold all my other equipment.
keith
12-01-2002 18:56:34
I farm very small with a 300 INT massey harris 50 and a super 77 oliver old cockshutt plow deering #7 mower and a roto baler and a good old JD rake and I have some binder, seeders,mowers that I dont use yet, disks and a 5 foot bush hog that I use on the massey. All the tractors were made in 1956
keith
12-01-2002 18:55:28
combine boy
12-01-2002 18:33:28
I farm 40 acers and this is the machinery that i use....
jd 620 with 45 loader
jd 730 2 row hard land lister
jd 2 row go deviel
jd 13 foot 3pt weed destroyer
jd kwa disk
jd 40 combine no cab 205 corn head 8 foot grain head
jd 55 cab 13 foot head 3 row narrow corn head
case 2-14 plow
burkens flair box wagon
allis chalmers roto baler orange top
jd 50 foot hay elevator
case 7 foot bar mower
case 15 corn chopper
david bradley stalk cutter wiht transport wheels
david bradley 4 wheel rake
wetmore hammer mill
jd EE grain drill steel wheel
jd 227 frount mounted corn picker/ case pr 1 row
clipper seed cleaner
Brother-Bob
12-01-2002 17:36:34
I still use a 1949 Farmall Cub
with a sickle bar to cut under fences
Dan
12-01-2002 16:16:25
I still use old tractors and equipment to farm my place. I have small acerage and the tractors and equip were mostly inherited or ppurchased really cheap. I have my dad's 1938 G that he bought new, a 1950 MT, 54 IH SMTA, and a new 1959 JD 430 with loader.Kinda envy the guys with cabs with heat and air at times, but my stuff gets the job done just a little slower. All the tractors run good including the G.
jake
12-01-2002 17:25:43
 Re: Re: who farms with the oldest tractors Equip in reply to Dan, 12-01-2002 16:16:25
i farm with 2 806 diesel 2pr corn picker 56 planter 6-14 ih plow and 37 disks 45 field cultivator newest eqip. vicon mower and 605f vermeer baler older is better
Richard
12-01-2002 15:14:12
Even tractors built in the 60's are 40+ years old now. And alot of them are in the fields. I see tractors built in the 50's and 40's doing alot of auger work, general duty. In my area it would be rare to see a tractor from the 30's involved in serious field work outside of having fun. Most are in parade duty.
jack
12-01-2002 16:16:43
 Re: Re: who farms with the oldest tractors Equip in reply to Richard, 12-01-2002 15:14:12
yeah poor people with alot of time on their hands.
Dick Davis
12-03-2002 05:22:15
 Re: Re: Re: who farms with the oldest tractors Equip in reply to jack, 12-01-2002 16:16:43
There is a unstyled John Deere (can't remember the model but has chain operated front steering) that makes the tractor show circuit. The orginal family makes a point of plowing a number of acres each and every year to work on the "Continously Used in Active Farming" braging rights category. Dick
