John Deere Plow
Dave in Ohio
12-01-2002 11:48:57
Which is the correct model JD plow for a 1951 JD AR ? Would like to do some plow days next spring.
Bob Collins
12-01-2002 12:06:08
 Re: John Deere Plow in reply to Dave in Ohio, 12-01-2002 11:48:57
Dave, If you mean by correct, the plow that was built the same year and likely what the farmer got if he bought tractor and plow together, then either a 44 (2 bottom) or 55 (3 bottom) series plow would likely fill the bill. These could be either clutch lift(pull the rope) or power-trol using a hydraulic cylinder and either series had a couple variations. Remember, all farmers didn't get a new plow with every new tractor so any 2 or 3 bottom plow you can pull and feel comfortable with could be considered "correct." The main thing to look for is a smile on your face when pulling it.
