John Deere 14-T baler
src
11-26-2002 06:41:53
I have recently purchased a John Deere 14-T baler
that is in need of knotter work. Are knotter parts
expensive for these balers? Is JD the best source
for parts, or should I try someone else?
Thanks.
jkoch
11-27-2002 07:30:55
 Re: John Deere 14-T baler in reply to src, 11-26-2002 06:41:53
Yes, some partss are availalbe for this baler, knotter is similar in operation to current, ..... contact Holland & Sons for parts at (815) 288-4441, ask for Brett.... jonathan koch email [email protected] see web site www.deeredealer.com
John Deere Pull Power Press
11-27-2002 05:46:15
I have a old horse run hay bailer that was my father's. It is called a John Deere Pull Power Press. Could any one give me any info on this equipment.
moonlite
11-27-2002 03:02:31
Most knotter repairs involve adjustment rather than replacement of parts. This is different than repair of most other agricultural machinery.
moonlite
11-27-2002 02:58:42
moonlite
11-27-2002 02:55:29
moonlite
11-27-2002 02:55:23
moonlite
11-27-2002 02:54:05
JMS/MN
11-26-2002 16:53:30
Years ago I had a 14T baler, and in a first cutting of 5300 bales, it missed three ties, and that was when it was switching from one ball of twine to another. My NH replacement baler was also excellent at tying. Either one has to be adjusted properly, and the owners manual gives great examples of good and poor knots and how to make the adjustments. I still have a piece of barbed wire that I found in a hay bale, with the knot tied perfectly around the wire- that came from the NH baler.
Dick
11-26-2002 16:46:48
Based on my experience these knotters are a real problem. 14-T's just don't tie very well. I'd suggest a parts and service manual and lots of patience.
Dick
11-26-2002 16:46:09
Ken B
12-01-2002 10:05:06
 Re: Re: John Deere 14-T baler in reply to Dick, 11-26-2002 16:46:09
I grew up putting up hay with a 14T & can honestly say that it was a vary reliable baler.Any square baler will miss ties if it isn't adjusted properly.I still have the old baler & use it each summer.We don't put up many small bales any more, Since we went to big round bales in the late 70's.I baled around 800 bales last summer only missed a couple ties.Keep up maintance on theese old machines and they will last a long time.Parts are still available from your local deere dealer.If your haveing troubles there is no substitute for the operators manual.It is very discriptive on noting problems. KenB
Sam
11-26-2002 11:25:39
I have an entire 14T parts baler I will let you have for $200. Complete with knotters and manuals.
src
11-27-2002 05:50:31
 Re: Re: John Deere 14-T baler in reply to Sam, 11-26-2002 11:25:39
Sam, where is your parts baler located? I might be
interested in looking at it.
Sam
11-27-2002 07:02:07
 Re: Re: Re: John Deere 14-T baler in reply to src, 11-27-2002 05:50:31
I'm located in east central Indiana.
src
12-02-2002 05:46:50
 Re: Re: Re: Re: John Deere 14-T baler in reply to Sam, 11-27-2002 07:02:07
Sam, I'm located in central N.H. Thanks, anyway.
smirkey
11-26-2002 10:55:50
if you need a lot of parts i'd look for a parts machine. a bill hook or knife arm alone are probably 50 each. if you change only those, you'l spend 200.
JMS/MN
11-26-2002 22:29:06
 Re: Re: John Deere 14-T baler in reply to smirkey, 11-26-2002 10:55:50
I spent $100 on a new bill hook in Sept 1974 on that NH baler, and it still works fine. Buy a parts machine and buy old parts.
Colorado Curt
11-26-2002 10:31:06
Deere is the best source for parts. They have a great web site that allows you to look at the assembly diagrams and to order parts. If you are a resonable mechanic and have the manual you should be able to do the work yourself. I have timed and worked on the knotters on a 14T and it is fairly simple. One thing to check (that is not in the manual)is the arm that turns and raises the needles. The hole in that arm had worn and was causing too much variability in the knotter timing. We filled and re-drilled that hole and the baler would tie all day with-out a miss.
Mike
11-27-2002 07:37:22
 Re: Re: John Deere 14-T baler in reply to Colorado Curt, 11-26-2002 10:31:06
Curt,
Would you let me know what the address to this web site is? I haven't found this before and would like to take a look at it.
Thanks.
Colorado Curt
12-02-2002 06:53:48
 Re: Re: Re: John Deere 14-T baler in reply to Mike, 11-27-2002 07:37:22
Here is the URL. Go to the parts section. You will have to register.
Tom
11-26-2002 07:25:06
The parts are readily available from Deere. I would have them do the work. Its not that expensive and can be a real pain if not done right
Dick2
11-26-2002 14:33:40
 Re: Re: John Deere 14-T baler in reply to Tom, 11-26-2002 07:25:06
We had a 14-T baler that we had to time occasionally over the years. Dad could fine-tune the knotters because they are the same as the binder knotters he was used to. The needles are maleable iron and can be straightened to the contour of a new needle; sometimes we bent them slightly to bring the twine into the knotters better. Once you understand it, the 14-T is a very easy baler to keep operating.
