: : : I want to overseed an existing weak hay field with a mixed seed using alfalfa, timothy, KY31 plus a couple more types to strenghten the field. Not being a real farmer, could use some ideas on how to do this; till, no-till, drill, seeder, etc.. Need to do it with as little field time as possible and keep cost low. Open for ideas and located in central OH. Thanks! : :Tom: Forget about the overseeding for a while and make DAMN sure your fertility is right up there. Otherwise whatever you do is a waste of time and money. How long has your field been down what kind of soil, what kind of plants are there and at what population. If you,ve got a weed problem, spray them. If you,ve got the plants there that you want and they have been down for less than five years, then throw the fertilizer at them. Unless you,ve got a premium livestock market or need a certain type of hay that you don't have, fertilize it before you tear it up. If you have an old stand of alfalfa (more than three years) you MUST kill it, spray or till before new legume seeds will germinate. There is an autotoxicity factor at work that will derail new legumes. If you seed new legumes, put on double or triple the amount of bacteria inoculant required. It's cheap, an excess hurts nothing and it's one more factor in favour of a new seeding. If I sound emphatic, I'm a seed salesman and I've seen too many people blow a ton of money on seed they don't need or they take short cuts in laying down a new stand. If you go short on anything, make it tillage. These seeds aren't that delicate, but they must have moisture fertility and minimized competition. Good luck. Tom Hello Tom: Tom from Ontario is right about fertility is ! You can do this by getting with your local County Extection office or a good local co/op get a soil sample have that tested for what you are planting and they will help you, With out this you'll be spinning your wheels trying to get something to grow,I put in 6 acres of horse hay in mid Oct. I needed 1000 lbs per acre of lime pellets & 600 lbs per acre of 19-19-19 it was a little expensive I planted seed at 18lbs per acre, but I have a excellent stand of hay at 6 weeks for next year Good Luck Mike Huber
