Properly aline and tighten belt on woods 42 mower deck on cub tractor
SCOTTY
10-07-1998 13:28:44
Need to know how to properly tighten and aline belt on a woods 42 mower mounted on a farmall cub. The diagram on the pulley cover is in rough shape but what I can get out of it is the 2 idlerpulleys are to be even with each other and the bottom of the pulleys should be 1 inch below the groove in the pulley on the mower and to lengthen or shorten the belt is done at the rear of the tractor by sliding the pins in the right hole for the right length. But I don't know if I have the right length belt. and what about that crazy pto pulley and hub is that suppose to be on the pto shaft a certian length and which side of the pulley should the hub flange be facing? Thanks for any help SCOTTY
