Welding grooves in needle
NHBalerman
11-14-2002 18:49:48
Does anybody weld up the worn grooves in the eye of the needle? I have tried to braze it and had fairly good luck except that the brass is so soft that it won't last very long. I can fix a baler but I ain't much of a welder. What is the best way to weld them and be able to grind them down smooth? Thanks
Burrhead
11-15-2002 20:08:59
 Re: Welding grooves in needle in reply to NHBalerman, 11-14-2002 18:49:48
I smooth bore a stainless steel nut and braze it in the holes.
Steven M
11-15-2002 15:25:11
I use machinable nickel.
