What plow is it?
Noly
11-10-2002 12:23:11
have acquired an IH 2-16 pulltype with clutch lift on rubber including hard rubber tail wheel. lettering on tail wheel is "BF Goodrich Silvertown implement type plow tailwheel" number on main beam is PO12572A, bottoms are numbered 515710R SC What model is it, what colors should it be, and what tread on tires. Has wore out 6.70 x 15 car tires. thanks for your help
Hugh MacKay
11-11-2002 13:14:54
 Re: What plow is it? in reply to Noly, 11-10-2002 12:23:11
Your plow could be a No.60. Does it have a box main beam? If yes it is a 60. Some of the older plows did have rubber tires, but no box main beam.
Noly
11-11-2002 15:34:14
 Re: Re: What plow is it? in reply to Hugh MacKay, 11-11-2002 13:14:54
not a box frame, levers are adjustable for length possibly a #8 Little Genius?
Hugh MacKay
11-11-2002 15:50:33
 Re: Re: Re: What plow is it? in reply to Noly, 11-11-2002 15:34:14
I would say yes to little genius no. 8. If it does not have the diagnol box beam across the top.
Hugh MacKay
11-11-2002 15:50:12
Noly
11-11-2002 18:21:45
 Re: Re: Re: Re: What plow is it? in reply to Hugh MacKay, 11-11-2002 15:50:12
thanks
Noly
11-11-2002 18:20:38
thanks
