John Deere Model 44 Plow Restoration
Wes
11-03-2002 08:05:11
I'm in need of 2 14" plow shears. Any one know where you can get NOS or re-surfaced plow shears?
Also where can you get the propper decals for the plow? I think there were four decals, two on the frame that said John Deere and Model 44 and two that said HS John Deere NC on the back of the mole boards.
Blaine
11-03-2002 11:42:53
 Re: John Deere Model 44 Plow Restoration in reply to Wes, 11-03-2002 08:05:11
Hi Wes,I'm also restoring a model 44-H plow.Do you know the numbers on the plow shares? Also on the decals my plow has a decal on the front cross brace that says ? 16 FRAME,I can't make out what the first part says-I do know the frame can be adjusted for either 16 in. or 14 in. bottoms. Mine is set for 14 in. Have fun Blaine
Bob Collins
11-03-2002 13:29:34
 Re: Re: John Deere Model 44 Plow Restoration in reply to Blaine, 11-03-2002 11:42:53
Blaine, There were at least two different decals used at different times for the frame size, mine like yours says "No. 16 FRAME" I have seen them that have a different wording, can't think of exact words right now. You are right about being able to switch offset standards to use different size bottoms (14"-16", or 12"-14") I think the label Wes asked about, on the back of the moldboard was a stencil and was different for each of the many different bottom assamblies available for this( and any) plow. In Wes' case the NC stands for narrow cut and means the point is cut at an angle at the back end to cut less than the measured distance. The HS refers to the shape and use of the bottom assembly. There should be a number between the HS and NC. This is what the dealer would need to get the correct parts for that bottom assembly. Many of the aftermarket suppliers should be able to supply points (shares) K&K or Travis Jorde are the Decal suppliers that can likely help.
Wes
11-03-2002 16:29:47
 Re: Re: Re: John Deere Model 44 Plow Restoration in reply to Bob Collins, 11-03-2002 13:29:34
A stencel on the back of the moleboard says HS 314 NC.
I have not cleaned up the old shares yet. I will look for a number.
Thanks
Wes
11-03-2002 16:29:29
Thanks
52BMAN
11-06-2002 07:58:06
 Re: Re: Re: Re: John Deere Model 44 Plow Restoration in reply to Wes, 11-03-2002 16:29:29
I think the HS stands for High Speed moldboards. I am restoring a No. 44H plow, and my moldboards say HS316 on the back. My decals feature the old 4 legged leaping deer and they say John Deere, Moline Ill. I know Travic Jorde has these decals.
52BMAN
11-06-2002 07:55:58
Wes
11-08-2002 18:38:13
 Re: Re: Re: Re: Re: John Deere Model 44 Plow Restoration in reply to 52BMAN, 11-06-2002 07:55:58
Thanks for the information. Today I sent a Email to Jorde's about decals. I can only find (lots of rust on the frame) 4 decals or lettering on the plow, John Deere on the rear cross member or brace, # 44 on the next brace towards the front and on the back of each of the moleboards HS 314 NC with a line under the 314.Were there any other decals on the plow? It is a model 44H.
I have a model 52 that has the leaping deer on the back of the moleboards
Thanks
Wes
