Today, the cornstalks won. This is my first round baler, & I realize it's an older baler. The stalks like to pack up in the pickup corners. But I can deal with that.The problem is the slip clutch goes. Got 1 bale blaed, & the machine stopped, could not get twine on it. Started the next bale, got 1/2 bale, & slip clutch went. Started a third, got 1/4 bale, & slip clutch went. Grrr. Doesn't look like a very adjustable slip clutch? It appears that corn stalk stuff is accumulating behind some of the rollers, and this is packing up the machine, stopping it. Is this a sign the slip clutch is bad, the stalks are too wet, or the belts are too smooth? Or any ideas? The machine made 40 bales of alfalfa & grass hay just fine on third cutting. Oh, & I chop the stalks, raked 3-4 rows together. We are having a very, very wet & cold fall, finally 3 days of low sun & about 40 degrees, don't know if the stalks will get much drier here in MN. Any suggestions would be nice, as it was along day. Flat tire on the plowing tractor, siderake fell apart, & a hole in the stalk chopper was throwing cobs at me. I've got some repairing to do tomorrow! :) --->Paul
