Road trip a baler- NH 68
Kelly C
10-27-2002 03:55:34
Wow! I made it home. 110 miles taking back county roads. Had one tire blow out on me and had to make a hasty trip to to a tire store and get a replacement. Took about 7 hrs at 25 to 45 mph and I only got lost once, well not lost just stuck behind a bunch of dead end roads. I needed to get into the next county and every stinking road dead ended along some low country. My map showed roads going through but they did not. I could see the other end accross the swamp but no way to get there. I thought I would be stuck in the middle of no where but I found a no maintanece road and got through.
Now I need to do it again. My parts baler is still there.
Wish me luck and a better route.
Kelly
casered
10-27-2002 19:14:54
 Re: Road trip a baler- NH 68 in reply to Kelly C, 10-27-2002 03:55:34
Was just chaecking out your web page. Nice stuff you have there. Just wanted to say that we have a 68 hayliner NH baler. We used it this summer for baling straw for the first time in almost ten years. The baler had sat unused for all that time. All we did was pull it out of the shed, wash it off and grease it up. It missed about the first ten bales because the twine was hanging up on the bill hook. We took off the steel arm that pulls the knot off the knotter and cuts the twine and sharpened the knife and bent the arm being sure to mearsure that we didnt bend it too far that it hit the billhook and this solved the problem. We used it to bale about 700 bale with it missing maybe twenty out of the 700. We have just in the past three weeks purchased a 273 hayliner that has a thrower on it. Going around to pick up all those bales took up more time then we really have too spend on the job. Besides the fact that it was a chute baler I had no problems with it at all. If yours works as good as ours did you will have a good baler for years to come. Good luck and keep us informed of your progress.
Chck, WA
10-27-2002 07:07:32
:) Just did the same last weekend...JD214 baler. Don't know how big yours is, but mine's a small square baler - but big enough for a newbie and my Ford Ranger. Towed over back roads, paved and gravel, about 70-80 miles. Took about 2-1/2 hours. I was real nervous, since I've never tried anything like that before. Piece-of-cake! It had sat in a barn unused for several years and the larger tire was buried in the dust to the rim, and the smaller one shot. We put one new tire on it and pumped up the other, and both made the trip fine, but the new one has settled in the week since then. It's blocked now till I have time this winter to wor on it to get it ready for grass hay next summer.
Good luck on your parts baler tow!
