Sickle-Bar mowers come in 2 types: Rear-mounted or Side-mounted. Rear is easier to attach, sides are more manuverable, easier to watch, but are an all-day job to get on or off. Most farm equipment companies once made sickle-bar mowers. Old ones were pull-behind units, but in the 1940's Ferguson/Ford started designing units that mounted on their 3-point hitch and were driven by the PTO. By the 1950's, most companies had added a 3-point/PTO unit to their line-up, including side mounts. 5 and 7 foot bars were pretty standard sizes. They WILL cut saplings as big as your thumb easily (if set up right), along with anything else that gets in their way. In the 60's, combines that cut, raked, and baled the hay in one pass made most sickle-bar mowers obsolete. Only a few companies still make them today, so your choices are between a new, expensive unit, or something 40 or 50 years old that hopefully still works. For a tractor like an MF-35, I'd look for a Ford 515 or 501. The 515 is better at cutting above or below horizontal, but seems to be more rare. Ferguson made a lot of different mowers in the 50's, as did Deere, New Holland, etc. I have an Oliver 355 that works great for me, but I spent a lot of time putting it back into good shape after it laid in a swamp for 20+ years. I'd probably avoid the earlier Dearborn or Ferguson mowers, they're too complicated, and hard to mount. You'll need to look around for a good one, as it could be anywhere. A good website I found was for Wenger's of Meyerstown, PA. They've got lots of mowers for sale, and even if you don't buy, you can look at different types and get some good pricing info. Good luck!
