Loader bucket convert to quick attach
Ralph Butteris
10-16-2002 13:02:10
I am tired of fighting with the pins on loaser bucket when changing from bucket to bale spear. ANyone know of a conversion for quick attach. I have a Westendorf wl-21 loaser.
Shep
10-17-2002 05:27:20
 Re: loader bucket convert to quick attach in reply to Ralph Butteris, 10-16-2002 13:02:10
Westendorf makes a quick tach for their newer loaders. You can buy the arms for the tractor side and weld the brackets on your buckets and you simply pull two levers and tip the bucket and they come right out. I know you can get the parts that you weld to the buckets for about $100 per bucket and I dont know what the ends for the loader cost. Talk to your local Westendorf dealer and see what they say.
Ralph Butteris
10-17-2002 06:07:54
 Re: Re: loader bucket convert to quick attach in reply to Shep, 10-17-2002 05:27:20
Shep, Thanks for the info! No local Westendorf dealer. I will email them for info and pricing.
JMS/MN
10-16-2002 23:14:51
A company in South Dakota makes one for JD loaders and many others. Do you have Fastline Magazine? Should be in there. Early model that I have is not as handy as the later ones- locking handle was improved- any good engineer should have figured out the improvement before marketing the attachment, if he had just bothered to use it a few times.
Ralph Butteris
10-17-2002 06:16:55
 Re: Re: loader bucket convert to quick attach in reply to JMS/MN, 10-16-2002 23:14:51
Thanks for the reply, I'll check my fastline for it. Ralph
hay
10-16-2002 13:55:52
i don't know what brand tractor you have, but it might be worth your time to take a look at the QUIK-TACH on the john deere tractors. all i have to do is remove two litch pins at the bottom on each side and then lower the bucket and back out from it and also simple to re-attach. just drive up to the quik-tach brackets and lift the bucket and re-install the litch pins at the bottom pins. perhaps you might be able to modify your loader to accept something like that. just my 2 cents worth. be safe!
Ralph Butteris
10-16-2002 14:05:32
 Re: Re: loader bucket convert to quick attach in reply to hay, 10-16-2002 13:55:52
That is what I am lookin for. The quick attach brackets for bucket and hayfork for WL-21 loader
