J D Disc bearings
Stan
10-12-2002 09:22:26
I have an older JD disc, it is a model PKO3. Is there another source for bearings other than the dealer?
paul
10-12-2002 18:04:12
 Re: J D Disc bearings in reply to Stan, 10-12-2002 09:22:26
Is that the cast iron holders? Try Shoup - I think www.shoup.com - they carry all sorts of disk parts. Got bearings for my WB JD disk.
NAPA could get them if you have a part number, but JD doesn't like to share.... ;)
--->Paul
Jim in Uk
10-12-2002 12:00:47
You may want to try shopping at Gebo's or TSC. Another place you may locate the bearings is at the local bearing distributor. Where I lived at prior to joining the service, there was Midcap and King Bearing Companies. I usually could find the bearings that I needed for most different equipment that I was working on through one of these parts houses. Good Luck
