Tom I know you already know how but I'm gonna go thru how I do it for anybody that has'nt fooled with it that might read this. I spread 125 lbs 60-40-30 fertilize per acre then disc it in good to pulverize the ground then scatter and disk in the sprigs then run a cultipacker over it. That way does really good. I go and watch a friend & neighbor who bought the planter to do commercial works and watch how it's done. It reminds me of a sweet potato slip planter. As the drum turns 2 men keep it loaded with sprigs. It has steel spades like the tater machine that place the sprig and a disc wheel closes the furrow on them. It has a 2 man station that when in operation those 2 men ride the planter to keep the feeder boxes full as it plants. They measure the seeding rate by bales per acre. The bales are exactly like small square forage bales. This Vermillion(sp?) adjust output by the drum speed as it pertains to ground speed. It will adjust from 2 bales on low up to 10 bales per acre on high output. This feller gets $50 per acre for the sprigs with 2.5 bales per acre and planting them. That's if you do all the prep work and do all the rolling. I put 5 bales per acre onto pulverized ground by hand, then disc it in, then roll the cultipacker over it. So far my fields look as good or better than the ones they have used the machine in. If I could find a manure spreader around here that's what I would use. If I got scatter brained on you or you need specific info just holler and I'll round it up for you, but as for how to put the sprigs out I would'nt pay for a machine or even rent one that I can out do by hand. One rental place in Houston rents the machine for $150 per day. I can put 4 men in a trailer for $160 per day and cover 1/2 again as much ground as the machine. Plus by using manual labor I have my both my tractor man and loaders with me at all times.
