Potato Plow?
David
10-07-2002 03:35:14
Does anyone know where I can obtain A potato plow?? I saw one once that was similar to a middle buster, only larger, and had steel rods protruding from each side aprox 18" long. It was for a 3 pt. hitch.
Burrhead
10-08-2002 20:40:42
 Re: Potato Plow? in reply to David , 10-07-2002 03:35:14
I use a double lister plow to lay off tater rows. Some folks call them a double shovel plow.
It's a double barrel middle buster is all it is. I gave $40 for it at a farm equipment auction. I think a new one is only about $175 if you get a Howse or cheap model like that.
It hills the bed but you have to hand drop the seed and kick dirt over them. It automaticly keeps your rows straight and uniform because you follow your tread tracks from the row before.
Then to harvest I use a regular middle buster.
Rob
10-08-2002 11:10:25
I am interested in knowing is that for "hilling" up the dirt before you plant the potato? or for digging them up in the fall. I would love to have a plow for hilling and also would love to have a device for digging too.
Thanks for the info and hope you can find one and then maybe I could find one
Rob
Tom A
10-08-2002 12:38:03
 Re: Re: Potato Plow? in reply to Rob, 10-08-2002 11:10:25
Rob:
It is for both planting and harvesting. It is a wide flatish sort of blade, set at a fairly shallow angle. In the spring, it'll make a wide farrow about 10" deep with the soil pushed up on both sides of it. I plant my potatoes on the bottom, and as the plants grow I push in a couple inches of the soil from each side, maybe 2" every two or three weeks.
In the fall, the shallow blade slides under the 'taters and lifts them gently out of the soil and sets most of them on top of the furrow. I used to harvest by hand with a fork, but what used to take me an entire weekend now takes about an hour.
Middlebuster should do about the same, although I suspect you'll lose a few taters to nicks and cuts.
I only bought the thing cuz an old retired farmer friend of mine kept bugging me to find one and use it...said once I did, I'd never go back to digging by hand and he was right.
Tom
Tom A
10-08-2002 12:37:25
Rob:
Tom
Tom A
10-08-2002 12:36:23
Rob:
Tom
dave
10-08-2002 12:17:14
WE just use a middle buster to make the furrow, and they are available easy. It is about 14" high, and in a V shape. it will also dig the potatoes,
but not as well as the one I described, that i am looking for.
dave
10-08-2002 11:48:01
Rob
10-08-2002 09:30:54
Rob
Rob
10-08-2002 09:28:49
Rob
Tom A
10-07-2002 04:21:47
I picked mine up at an estate auction, paid $25. I see them periodically for sale in the regional "Pennysaver" paper or classifieds, usually for less than $100.
I can't remember ever seeing one new for sale anywhere.
Tom A
David
10-08-2002 03:26:42
 Re: Re: Potato Plow? in reply to Tom A, 10-07-2002 04:21:47
Only ever saw one, and it was at a auction. It looked pretty new. Thanks
