Precision of the knife to the guard plates
Eric Midgette
10-05-2002 18:18:06
I am currently putting a JD No.5 mower back to working condition. Right now I am working on the sickle and am trying to determine how "tight" the play between the knife and the guard plates need to be. The Operators Manual states 1/32-1/64th". That appears to be very close, especially if it is to be that precise at all guards. I can see where the cut would be much better the closer it is but..... really..... that close?
Paul R.
10-07-2002 11:09:55
 Re: precision of the knife to the guard plates in reply to Eric Midgette, 10-05-2002 18:18:06
Depends somewhat on what you're cutting. I cut thick grass / brush / cat-tails along the edge of my pond, and it cuts pretty good with a gap of up to 1/8". For cutting regular grass, you gotta keep it as tight as you can get it. It's actually quite an art lining up the guards, knife and hold down clips, but it's usually worth it. People who don't think much of sickle-mowers probably never ran one that was adjusted right.
Alvin NE WI
10-05-2002 18:55:22
when you have it close like the manual states, it will cut clearner and easier. When the gap gets more than that, it will start to plug at the sickle, espically the grasses amd worse when some what damp..
