Shredder
REA
10-04-2002 16:11:27
Hi, I have a 3 point hitch Kemp Shredder that I use around the house to grind leaves and small sticks. It will also chip wood up to 3 inches in diam. My problem is when I grind things like corn stalks or something green it binds up. Is there something out there that is better? What is a Flail Chopper would that do a better job? My tractor has 21.69 HP at the drawbar. Thank you Any help will be appreciated. Bob
Ron_NY
10-06-2002 06:04:43
 Re: shredder in reply to REA, 10-04-2002 16:11:27
I have a powered Kemp Shredder (Master Gardener model) with 8 hp Kohler engine. The shredder works great on dry materials, but high moisture material will jam it up in minutes. I always have this problem when I am trying to shred material that I have stacked in my compost bins. Mixing wet and dry has not been successful for me, as the dry material just gets stuck to the wet material already blocking the holes. I have considered keeping a hose available, to push the material throught the holes, but I am usually working too far away from the hose. The jaming occurs while using the "standard" screen, with 3/4" holes. There was a "bar grate" available, which would let material pass through very quickly, but I found that it didn't chop the material as fine as I wanted.
If the knives are worn, they are designed to be fliped over, giving a new solid shredding surface.
Just in case you are unaware, Kemp Manufacturing Co. went out of business in 1994. The following company took over their parts inventory and may still have parts available. (I haven't contacted them recently)
Geen Acre Lawn & Garden
171 Green Acre Road
Lititz, PA 17543
(717) 626-6511
No web site that I am aware of.
Good luck. Ron in Central New York
John S-B
10-05-2002 10:07:17
You may need to wait until stringy vegetation like cornstalks are dry before you run them through a shredder. If your shredder has been in use for a while your flails may need to ground flat, or like in mine there is a blade that looks like a small lawn mower blade that has to be sharpened occaisionally.
