JD 567 hay rake
Jim E
09-26-2002 20:53:54
Need info on this rake as in does it rake decent? Any tricks I need to learn. Dealer won't get the book in until next week. Was going to post this on the JD board but....
Thanks!!
Wheels
09-28-2002 11:07:53
 Re: JD 567 hay rake in reply to Jim E, 09-26-2002 20:53:54
Jim E
If it is in good shape, it should do a good job, the front two wheels seem to be crooked on ours and won't pick up a rained down in the stubble windrow. The back ones will pick it up just fine. You may have to slide your tractor hitch one way or another to keep your tires from running a windrow down (assuming hay was cut with a haybine). If Possible try not to drive where the windrow will end up, if it stays in the stubble it will dry better. Unless it was taken apart for shipping it should be set were the previous owner used it and should work for you.
It is getting hard to find them in good shape as the wheels are wore out in most of them and cost $$$$ to replace. My parents saw a good one at a auction last week that went for $250, wish I had been there.
Good Luck
Wheels
