I have never used a 3-point plow, only hitch plows years ago & semi-mount (hook onto the lower arms of the 3-point, but no upper link, run on 1 rear wheel) plows now. I have never used a disk plow, only molboard plows. So, my observations probably don't mean much. I've always felt your 3-point pins are quite high. In my plowing, things always work when the plow is being pulled from as low as possible. I notice the original set-up of that plow had some very low pulling brackets. Pulling high loses you a lot of traction, and will cause the plow to want to tip out of the ground, giving you poor draft (will want to buck up & down like a bronco). My semi-mount plow, the bottom of my tractor arms are shiny & smooth from basically dragging on the ground. (It would help to see a pic of the action - how it looks when the plow is in the ground.) Also, I've never used sway stablizers on a plow. For the molboard, it works much better to allow it to find it's own path, it will trail in 1 place most of the time. You need to either move the wheels of your tractor, or the frame of the plow, to line the furrow up. It sounds like your tractor does not have movable wheels, and you may have made a solid frame? Many plows have a clamped-on drawbar that can shift left or right. Trying to adjust the lower arms off-center can mess things up, make it want to pull to one side pretty badly. You are actually changing the angle of the plow left-right, as you pull the lower arms to one side. This will make things want to slap left-to-right & right-left as you plow. Seems like a tiny angle when you shift the arms, but it does matter. If any of my observations apply to a 3-point, disk-plow - I have no idea! Good luck, and keep us informed. :) --->Paul
