Offset Disk
Kenneth Strawn
09-23-2002 17:32:57
What is an offset disk? Thanks, Kenneth
AGEN
09-23-2002 22:22:48
 Re: Offset Disk in reply to Kenneth Strawn, 09-23-2002 17:32:57
third party image
An offset disc is on that simply has two straight gangs of discs that are set at an angle to each other. From the top, an offset's gangs make a ">". On the other hand, a tandem has gangs that form an "X" when looking from the top of the disk. An offset will have a front row of gangs that throw the dirt one direction and the rear gang throws it back the other way. An offset is used more as a primary tillage tool while a tandem is used as a smoothing/leveling tool. Offsets pull much harder than tandems since they "bite" down into the soil more than do tandems.
