John deere two way plow
Dennis Schut
09-23-2002 07:57:07
I have found a 4 bottom land slide two way plow along a fence row. Does anyone know where to find a JD stamp on it? Also wondering if anyone knows the approx. years that these were built and what tractor was used to pull them. I would also be interested if anyone has a broad idea of its worth. Any help on any of these matters would be greatly appreciated.
iman mm
07-25-2003 22:31:27
 Re: john deere two way plow in reply to Dennis Schut, 09-23-2002 07:57:07
I am searching about two way plow
in sadi
07-25-2003 01:07:19
I want to knwo the types of rotating a two way plwo
Dan
09-24-2002 21:10:57
Are you referring to a roll over plow? Jd made a number of different models of roll over plows. If it is 4 bottoms total, 2 going each way, could be a JD 202. In operation 2 bottoms were down and 2 lifted up off the ground, at the end of the row when lifted up it tripped so that the other 2 bottoms went down and hitch swung to the side. Think this was also made in a single bottom plow, the 101. If a roll over plow, does it have a round mechanism on the front to roll the plow over (looks kind of like a power steering mechanism on a 530) or does it have 2 cylinders working up and down. More info would help to identify
Dennis Schut
09-25-2002 11:52:06
 Re: Re: john deere two way plow in reply to Dan, 09-24-2002 21:10:57
It is a roll over plow. It has 8 bottoms - 4 going each way. It also has a round hydraulic pump with 2 hoses to roll it over.
Dan
09-25-2002 21:23:03
 Re: Re: Re: john deere two way plow in reply to Dennis Schut, 09-25-2002 11:52:06
Sounds like an 845 I believe was the number. Older plow, probably 60s I think. They seemed to work ok if in decent shape. The rollover cylinder uses some of the same parts as the power steering units in 20 and 30 series. Most everyone here has gone to the plows that you just reverse the bottoms to go the other way.
Dennis Schut
09-25-2002 11:47:03
