Manure spreader advice
Tom A
09-18-2002 04:04:14
It is County Fair week, and the implement dealers are setting up side-by-side and actually competing a little. I think I'm gonna spring for a manure spreader this week. I've been looking for a small used one for a year but haven't seen one worth the asking price. I've got a mule, donkey, herd of goats and sheep. Might wind up with a few (3-4 tops) head of cows, but might not. That'll be about all I will ever have on this place.
So: assuming price is roughly equal, am I better off buying a PTO drive Pequea or a ground drive New Idea spreader? They're both about 50 bushel...anybody have any experience with either? I like the New Idea dealer better (already deal with him for tractor parts and critter equipment), but both are ok.
any thoughts?
thanks,
Tom
Jim CT
09-18-2002 08:54:22
 Re: Manure spreader advice in reply to Tom A, 09-18-2002 04:04:14
New Idea makes a 50Bu spreader still?Modle # and I'll price one myself Is it the PTO one or is the Peque?
TA
09-18-2002 09:34:15
 Re: Re: Manure spreader advice in reply to Jim CT, 09-18-2002 08:54:22
The NI is the ground driven one...it looks about the same size as the Pequea which is labelled 50 bushels (you know, dealers next to each other at the Fair can't lable stuff the same way or else folks can make smart decisions).
I'll probably be headed back to the Fair this evening after work and chores and get more info, I s'pose.
Tim(nj)
09-18-2002 18:50:19
 Re: Re: Re: Manure spreader advice in reply to TA, 09-18-2002 09:34:15
All current AGCO New Idea spreaders (according to my dealer, anyway) are PTO drive. Model 3709 is the smallest, at 59 cubic feet (90 bu.) If I remember correctly, a new one was quoted at $4800. If the 50 bu. ground drive you are looking at is really a New Idea, it's a very old reconditioned unit, or it is a Lancaster spreader (Lancaster builds new copies of old New Ideas). You have to watch out sometimes. A lady near where I live bought a "John Deere" mini-spreader this spring. Turns out it is a spreader like those sold in the Northern catalog, that somebody painted green and yellow and put on decals from a 318 garden tractor. Pays to do some research.
Tom A
09-19-2002 03:52:54
 Re: Re: Re: Re: Manure spreader advice in reply to Tim(nj), 09-18-2002 18:50:19
Sure enough, I screwed up the brand. It is a "Mill Creek" 50 bushel ground driven spreader vs a Pequea. Metal guage is the same as the Pequea, but somehow the Pequea does *look* a little more substantial. Don't know, maybe I'm going back to look at used ones again.....
Tim(nj)
09-19-2002 13:41:08
 Re: Re: Re: Re: Re: Manure spreader advice in reply to Tom A, 09-19-2002 03:52:54
The Mill Creek spreaders have a reputation among the stables in this area as being junk. The Pequea would be your better choice as far as durability is concerned.
Punchie
09-20-2002 05:58:13
 Re: Re: Re: Re: Re: Re: Manure spreader advice in reply to Tim(nj), 09-19-2002 13:41:08
HI Tom
ASk the dealer to show you it working, or someone that has one of the same make and model. ASk them to let you use it, try it out. You don't need one to work on they a Pain and they are well mess to boot.
Ground Drive : I use a older Oliver 50's-60's, I would say that the G.D. are good to use on almost any field, but not in mud. We have stones here and the mud and the stone get mixed together and get in the wrong places. If it get stuck to the tires they can get dropped off in the wrong place. I almost broke a gear one day. I bought this about 15 years ago for $300.00 and if I would sale it today I would ask $800.00 Western PA
PTO : I would say is ok. Better in a lot of ways , but I think G.D. does a better spread , no speed to control , PTO and Ground speed . G.D. is all gears and does a better even spread, Just remember if your spreading in alot of Mud PTO is the way too go. But still whatch the mud on the tires, may fall off into a drive or something.
Couple other thing don't use if too cold, chains may brake and gears. If you load up and a freeze is coming , better unload it , makes a big Block of manure. Don't overload, if you brake something , you thinks twice the next time, after you unload it by hand to be able to fix her.
Good Luck !!
Punchie
Bret
09-18-2002 05:12:18
Biggest advantage to PTO is that you can clean it out without moving. I have a ground drive IH and it was great except when loaded heavy on soft ground the wheels would slip and I'd end up forking it out. Fun, fun, fun. Far as Pequea vs.NI- Pequea appears to be built heavier than NI.
