John Deere Model BW Disc
Jack S.
09-17-2002 18:31:00
I just came across a model BW 14' disc, is in pretty good shape. The right rear gang has a bearing that feels loose. I don't have a manual yet, are these tapered bearings and are there any tricks for changing them out. Is the shaft nut tightend like for a wheel bearing, that is, tightend and then back off slightly? Any help would be appreciated. Thanks
Jim B
09-19-2002 09:05:18
 Re: John Deere Model BW Disc in reply to Jack S., 09-17-2002 18:31:00
Jack,if I remember correctly the BW has a cast housing that two tapered roller brgs go in from each side held by a snap ring.The disk shaft should be tightened very tight as this keeps disk from spinning on shaft.Jim B
Jack S.
09-19-2002 19:35:52
 Re: Re: John Deere Model BW Disc in reply to Jim B, 09-19-2002 09:05:18
Jim, Thanks you have been a big help.
