Quickhitch?
DIRTMAN
09-17-2002 16:24:38
years ago we some implements that hooked up by first putting on the tractor lower 3 pt. lift arms a hitch bar that had a tappered ball in the center.you then backed into the implement which had a wide mouth receptical to received it .accuracy wasn,t as important as the receptical would still receive even if you were off a little.does anybody still make this type hitch/hook up implement?i can,t remember who made the ones we had.my JD.630 oper.man.shows a hitch like this on a JD.630.thanks
paul
09-17-2002 23:48:32
 Re: quickhitch? in reply to DIRTMAN, 09-17-2002 16:24:38
Any implement dealer or farm supply store in Minnesota has them or can order them - I'm sure it's the same in your neck of the woods. There are several different sizes (cat 1, 2, 2wide, 3, 3 wide, 4), and some of your 'standard' implements might not be 'standard' after all, esp. the location of the top link, so start measuring your implements & see what you need. Suppose it will be cat 1, maybe 2.
--->Paul
