NH Haybine 467
Randy
09-14-2002 13:07:04
How large is a NH Haybine 467,and how much HP is needed to run it? Thanks, Randy
clough meadow farm
09-14-2002 19:34:43
 Re: NH Haybine 467 in reply to Randy, 09-14-2002 13:07:04
I used to run one of these with a farmall super C. Only had about 24 hp and it worked fine, used the pump for the fast hitch to operate the cyl on the haybine. My rollers where shot and couldn,t find anyone to repair or replace then so I traded it in on a new unit. If you need it I think I might still have the operators manual for it somewhere.
Frank
09-14-2002 13:17:02
The "7" in the 467 model number refers to the swath width of seven feet. Tractor requirement would be about the same as the current NH model 472 of the same width that lists 30 HP or greater as the tractor requirement. Note that the rubber rollers on these older 467-469 seem to have held up better than the 477-479.
Tim(nj)
09-15-2002 07:06:42
 Re: Re: NH Haybine 467 in reply to Frank, 09-14-2002 13:17:02
If the rollers are bad on this particular 467, keep in mind that New Holland no longer has replacements.
