NEW HOLLAND BALERS
JIMBO
09-14-2002 10:11:11
WHICH IS THE BETTER BALER OR THE FASTEST 276 OR 273 N H BALER? THEY ARE IN GOOD SHAPE
smirkey
09-16-2002 10:17:14
 Re: NEW HOLLAND BALERS in reply to JIMBO, 09-14-2002 10:11:11
276 is a superior model, its feeder is higher capacity than 273, makes good shape bales. it is even better capicity than the later 315 which breaks a lot of shear bolts.
ChuckKS
09-15-2002 18:26:56
The 276 is a higher capacity machine than a 273, in other words more strokes per minute, I have both machines and both are excellent, (even without packer forks).
ChuckKS
09-15-2002 18:23:41
Rick
09-15-2002 06:33:21
These are same age balers 276 little larger. I would stay away from any early New Holland because of no packer fork. I n those years I would stay with Deere. I have run both.
350 Don
09-16-2002 16:46:30
 Re: Re: NEW HOLLAND BALERS in reply to Rick, 09-15-2002 06:33:21
I would personally stay away from an early John Deere baler. We had one and the knotter was unrepairable, despite the best efforts of a John Deere mechanic who spent lots of time in the field with us. Except for the weak knotter it was ok otherwise.
Rick
09-17-2002 05:56:38
 Re: Re: Re: NEW HOLLAND BALERS in reply to 350 Don, 09-16-2002 16:46:30
350 Don. Said knotter was unrepairable on Deere baler. What part was it? Never heard of such a thing.
WILL
09-17-2002 18:42:31
 Re: Re: Re: Re: NEW HOLLAND BALERS in reply to Rick, 09-17-2002 05:56:38
THE 24T JD WAS A HAIR PULLER AT TIMES THIS GUYS HAY BARN WAS ON FIRE ONE TIME HE PULLED THE RAKE OUT WITH A CHAIN SOMEONE ASK HIM WHY HE DID,T GET THE BALER HE SAID IT WAS THE BEST THING THAT COULD HAVE HAPPENED TO THAT BALER WAS TO BURN THE BALER WAS 4 OR 5 YEARS OLD BEEN A PAIN SINCE NEW
jimbo
09-15-2002 17:05:41
does the packer fork mean that much the man selling it said it made good bales all day long but he is the salesman i can buy it for 1000 dallors thought it be good for a spare looks like it has not baled alot
Rick
09-17-2002 05:59:56
 Re: Re: Re: NEW HOLLAND BALERS in reply to jimbo, 09-15-2002 17:05:41
Jimbo, I sold a 278 for a fellow. $2800 was one owner been sitting probably ten years or more in shed. Just for your info.
Rick
09-17-2002 05:52:03
Jimbo, You said buying it for spare. What are you using now? New Holland now uses a packer fork in later models,what does that tell you. I still would stay with Deere in those years. You see lots of articles in this sight and other hay sights about banana bales thats why. They say Deere has knotter trouble. They use same setup both brands basically. Only difference in those years New Holland is chain driven Deere gear driven.
JIMBO
09-17-2002 13:13:00
 Re: Re: Re: Re: NEW HOLLAND BALERS in reply to Rick, 09-17-2002 05:52:03
RICK I RUN THREE 575 NH BALERS THREE 347 JD BALERS THE BALER LOOKED GOOD AND I WANTED IT I BOUGHT IT AND BALED 1200 BALES THEY LOOKED JUST AS GOOD AS THE 575 BALER BALES ITS GOOD TO HAVE A SPARE I DONT KNOW WHO TOLD YOU THAT JOHN DEERE KNOTTER GAVE TROUBLE I SPEND MORE MONEY ON THE NH BALERS THAN ON THE JDS THE KNOTTERS ARE FINE THE AUGER HAS BEARING TROUBLE NOT THE KNOTTERS JD MAKES A PRETTY BALE OF HAY OVER NH
paul
09-15-2002 17:10:02
Would sound like a good deal to me.
--->Paul
